I accidentaly did sudo apt-get remove python command and now terminal look has changed, rhythmbox, ubuntu software center and everything is quite changed. I reinstlled python with the command sudo apt-get install python but still nothing reverses. Terminal can't be opened throug dash but only through ctrl + alt + T How to get back the old ubuntu. Ubuntu is still working music is playing videos are being played( In VLC). I can browse net through mozilla. But still how can I reverse the effect? Should I reinstall ubuntu?
I was able to install rhythmbox and software center through uxterminal and then once software center was installed everything was installed and then I install terminal through software center.
kartikeykant18
  • 177
Just switch to the tty, you will have a login prompt, write your username/password, you will get a shell. So, now you only need to install python back, along with all the others packages, the simple way to do so is:
sudo apt-get install ubuntu-desktop
If you like, you can also install other metapackages instead:
apt-cache search metapackage | grep desktop
Braiam
  • 69,112
