Is it possible to add the Nvidia X Settings to the Panel so it can be worked from there? For example to have the ability to change resolutions, change AA, AF, Vsync, Detect other monitors, change refresh rate, etc..
htorque
  • 66,086
Luis Alvarado
  • 216,643
Disper maybe too limited for what you are asking but I think using nvidia-settings from the command line might achieve this. Use nvidia-settings --help or man for settings available.
The other program you may need is nv-control-dpy but that's not ideal as you need to build it from the source code before you can use it. It is very powerful though and I will be using it when creating a script for docking my laptop with external monitors.
To add all these commands to the gnome panel would be only possible with custom desktop entries (shortcuts) to the settings you want to switch.
Cas
  • 8,707
Try Disper. It provides an interface to Nvidia's settings from the panel (as far as I understand).
RolandiXor
  • 51,797
