I wish to change a menu entry in grub.cfg, for example:
From
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Ubuntu is wonderful'
To
menuentry 'Ubuntu is world famous'
Braiam
  • 69,112
n00b
  • 1,927
Edit /etc/grub.d/10_linux instead and run sudo update-grub when you are done. This is a more reliable method, otherwise every time you upgrade to a new kernel your /boot/grub/grub.cfg will be overwritten and you will lose your changes.
Or you can use Grub Customizer. To install it:
sudo add-apt-repository ppa:danielrichter2007/grub-customizer
sudo apt-get update
sudo apt-get install grub-customizer
Danatela
  • 13,384
How to do it from an emulator to learn how GRUB works, without the risk of breaking anything.
  • create a Multiboot hello world main.elf file. GRUB knows how to boot those files (GRUB also knows how to boot the Linux kernel, even though it is not Multiboot)
  • create a iso/boot/grub/grub.cfg file containing:
    menuentry "main" {
        multiboot /boot/main.elf
    Place main.elf under iso/boot/
  • Generate an image and run it:
    grub-mkrescue -o main.img iso
    qemu-system-x86_64 -hda main.img
This will boot into GRUB, and you will see an entry called main.
Now edit grub.cfg like menuentry "newmain", and upon a reboot the new option name is newmain. So your change would work.
I have posted the exact code for this example at: https://github.com/cirosantilli/x86-bare-metal-examples/tree/d217b180be4220a0b4a453f31275d38e697a99e0/multiboot/hello-world
As others said, don't do it in practice, since that is normally an output file and will get overwritten on update-grub.
