I have installed edubuntu 13.04 in one of my computers. Now I am unable to select or rather even move the selection in the GRUB during boot time. So Ubuntu is automatically loaded. I am unable to get into Windows 8. I tried boot repair once and got a link http://paste.ubuntu.com/7129807/ which I couldn't comprehend. What can I do to be able to access Windows 8? Help Required.
Firstly look at the position of Windows8 in GRUB menu, ie if Windows8 is at 5th position then consider it as an array and consider its position as 4.
In order to load Windows 8 on default just edit grub.cfg by typing in,
sudo gedit /boot/grub/grub.cfg
in the terminal, find for the line default=0 in grub.cfg and change the value to your previously noted value (In this case 4)
NOW ITS IMPORTANT TO UPDATE THE SETTINGS BY TYPING IN,
sudo update-grub
Alternatively you could also install GRUB customizer,
sudo add-apt-repository ppa:danielrichter2007/grub-customizer sudo apt-get update sudo apt-get install grub-customizer
I found this guy requesting for help to solve a boot problem that looks like yours: http://ubuntuforums.org/showthread.php?t=1515153
^They couldn't solve the problem, but they came up with a temporary solution: "I went ahead and burned a copy of supergrub boot disk to CD and am able to boot to all my partitions" Try to download and run Super Grub2 Disk for now.
