I downloaded ubuntu-13.10-desktop-i386.iso from my Ubuntu 10.04 LTS. How to install ubuntu-13.10-desktop-i386.iso from my Ubuntu 10.04 LTS
- 14,528
- 5
- 38
- 46
You must write the ISO to USB or CD/DVD as an ISO image using special tools like UNetBootIn or Brasero respectively (not just like your are saving a file); ISO image must have boot record
then insert your usb or cd into the machine
reboot the machine
quickly access your BIOS with hotkey on your keyboard (mine is Delete) some machines is different (you must first know what that is)
you can always restart your machine and hit hotkey to access bios before boot
you must find the boot selection in your BIOS
- (select cdrom if you have CD)
- (select USB to boot is USB iso)
with your cd or usb in your machine at restart the installation should begin by itself, be patient for this, the screen might go blank or black for a minute
when install is complete, the program will say to restart machine
do not take out your disk or usb
upon restart - access again your BIOS
change boot to HDD (hard drive you have installed OS on)
let machine boot up from HD with new installation
you can repeat these tasks if you need to
Practice makes perfect!!! Good Luck.
- 13,384
