I am trying to change permission and change the group permission of the folders which are shared through SAMBA (Samba PDC). Commands are as follows:
# chmod 766 /mnt/Format
but nothing changed.
Please help.
Please help.
The problem is because you use POSIX-specific command (chmod) to change non-POSIX-compliant filesystem (NTFS). The chown command also does not work on such filesystems. To change permissions on NTFS shares you should use mount options.
From man mount.ntfs:
OPTIONS
Below is a summary of the options that ntfs-3g accepts.
uid=value and gid=value
Set the owner and the group of files and directories. The values
are numerical. The defaults are the uid and gid of the current
process.
permissions
Set standard permissions on created files and use standard
access control. This option is set by default when a user map‐
ping file is present.
So, instead of using
use
mount -o uid=UID,permissions,remount /mnt/Format
See man mount.ntfs for further help. There is nice EXAMPLES section which helps understanding how mounting works.
