I want to install a spectral analysis tool for Ubuntu, and thought Spectrum3d looked good.
I've tried following the install instructions. As far as I understand, I am supposed to write:
sudo add-apt-repository ppa:nadaeck/spectrum3d
in the terminal. It doesn't work. I get the following error message:
Traceback (most recent call last):
File "/usr/bin/add-apt-repository", line 128, in <module>
ppa_info = get_ppa_info_from_lp(user, ppa_name)
File "/usr/lib/python2.7/dist-packages/softwareproperties/ppa.py", line 84, in get_ppa_info_from_lp
curl.perform()
pycurl.error: (7, "couldn't connect to host")
From my rudimentary understanding of linux, I should be able to write my sudo password here, but the characters I write are shown in cleartext. It never asks for my password
When this didn't work, I tried to download it from sourceforge and compile it, I also tried searching for it in the Ubuntu Software Centre, but I couldn't find it.
I downloaded the latest version and went to the folder and typed:
./configure; make; make install
I got the following output:
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking whether gcc and cc understand -c and -o together... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for GTK3... no
checking for GTK2... no
configure: error: GTK library (libgtk-2.0 or libgtk-3.0) is required
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target `install'. Stop.
So, how do I just get this program up and running on my system?
