I am stuck with 1024x768. Display comes up as a laptop. It's a Philips 17" I have no composition, 2D and fuzzy lines going up the screen.
I used the software centre to install the ATi X.Org binary driver. Useless! It loads Catalyst. If I click on Catalyst Control Centre, I get:
There was a problem initializing Catalyst Control Center Linux edition. It could be caused by the following.
No AMD graphics driver is installed, or the AMD driver is not functioning properly. Please install the AMD driver appropriate for you AMD hardware, or configure using aticonfig.
sudo lshw -c video gives:
    *-display UNCLAIMED
    description: VGA compatible controller
    product: RS880 [Radeon HD 4200]
    vendor: Hynix Semiconductor (Hyundai Electronics)
    physical id: 5
    bus info: pci@0000:01:05.0
    version: 00
    width: 32 bits
    clock: 33MHz
    capabilities: pm msi vga_controller bus_master cap_list
    configuration: latency=0
    resources: memory:e0000000-efffffff ioport:1100(size=256) memory:f0100000-f010ffff memory:f0000000-f00fffff
If I do it in terminal, it says missing dependancies and crashes..
I though I hadn't installed it, but:
fglrx is already the newest version.
fglrx-amdcccle is already the newest version.
fglrx-amdcccle set to manually installed
doing:sudo aticonfig --initial
aticonfig: No supported adapters detected
It's driving me mad!
I just want my 1280 back and Docky not complaining about compositing all the time.
user256787
  • 39
Unfortunately your card (Radeon HD 4200) is too old for the fglrx driver available in the ubuntu repositories to work.
You can try and install the legacy drivers from the AMD website:
http://support.amd.com/de-de/download/desktop/legacy?product=Legacy2&os=Linux%20x86_64
but note that these only work up to linux kernel 3.4.x !
So if the output of the terminal command uname -r shows a number higher than 3.4.x you cannot use that one.
In that case you need to uninstall the fglrx and amdcccle drivers that you installed by typing
sudo apt-get purge fglrx amdcccle and then install the old open-source drivers again.
sudo apt-get install --reinstall xserver-xorg-video-radeon
Daniel W.
  • 3,496
