Is there any way to install NVIDIA GEFORCE 750M drivers for Ubuntu?
Right now Intel Haswell Mobile is used for graphics. Is this ok? Can I get better performance by installing NVIDIA drivers?
I remember that last time when I installed something related to that, my Unity was broken. After uninstalling them Unity worked again.
Ionică Bizău
  • 9,803
  • 25
  • 89
  • 129
I fixed the problem by installing the tested NVIDIA drivers for Ubuntu:
I can see the following details:
So, GeForce GT 750M /PCIe/SSE2 driver is installed.
BTW, I switched again on the open source driver. NVIDIA drivers had important issues (overheating and sometimes the entire screen was freezing).
After applying changes and rebooting Ubuntu started in low graphics mode. I pressed ALT + CTRL + F1. I deleted the following file:
 sudo rm /etc/X11/xorg.conf
Then I restarted the PC:
 sudo reboot
My machine uses again the open source driver and it works fine. If you don't have big issues with the open source driver, I really recommend not to switch on the closed source one.
Ionică Bizău
  • 9,803
  • 25
  • 89
  • 129
Installing the drivers from NVIDIA website worked for me. just download the latest stable version for your card here.
Now, the only problem is the graphic server have to be down to install them. Save the file .run in your desktop and switch to a tty with Ctrl + Alt + F6
Log in and type the following commands:
sudo service lightdm stop
chmod +x NVIDIA*.run
sudo ./NVIDIA*.run
Follow the on-screen instructions. If it tells you something like "pre install script for your distribution failed" that's normal, just chose yes. When it's done, reboot with:
sudo shutdown -r now
Note that I've used the * but you could use the full name of the file, which depends on what version you download. I'd recommend you to use the latest stable, right now 334.21.
Did you give a try to 352.41 driver?
sudo apt-get purge nvidia*
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo apt-get install nvidia-352
I've the same processor, graphic card and memory (maybe same laptop? :D ). Neither bumblebee nor nvidia-331 made the trick for me, so I'm about to try 352.41 as suggested on Nvida web site.
I'll tell you later if it gives some help or not.
