I am attempting to dual-boot Ubuntu 12.04 with Windows 8.1, but I am unable to run a LiveUSB without turning on legacy mode first. In legacy mode I was able to install. I planned to fix the legacy mode problem by running boot-repair from the 'Try Ubuntu' option on the LiveUSB. However, boot-repair gives me the following error in an infinite loop:
"The boot of your PC is in Legacy mode. You may want to retry after changing it to EFI mode. Do you want to continue?"
I press yes, it says it is applying changes, then it gives me this prompt again, over and over. But it doesn't fix my boot. I have the 'Separate/boot/efi partition' option ticked.
So, if I can't run Ubuntu in EFI mode, and I can't run boot-repair in legacy mode, what am I supposed to do?
The strange part is, I had Ubuntu-Windows8 dual boot set up on this machine before and it worked fine, but I broke my Ubuntu side and had to do a fresh install. I remember that I had to run boot-repair to fix the legacy mode problem before, and it worked. Is there something I'm missing?
First, disable Secure Boot in your firmware. That might enable you to boot the live CD (or installer, for that matter) in EFI mode.
If that doesn't help, then I recommend you try my rEFInd boot manager. This lowest-risk way to do this is to download the USB flash drive or CD-R image and try booting from it. It should give you options to boot both Windows and Ubuntu. If both work, boot into Ubuntu and then install the Debian-package version of rEFInd. It should then launch from the hard disk when you restart the computer in EFI mode.
Rod Smith
  • 45,120
  • 66
  • 108
