I downloaded the source to a package using:
$ apt-get source gkrellweather
I also made sure I had the compile dependencies:
$ sudo apt-get build-dep gkrellweather
And I tested that it could build fine:
$ cd gkrellweather-2.0.8
$ debuild
It built a .deb package in the folder above, which I could install using:
$ sudo dpkg -i ../gkrellweather*.deb
OK so everything is in place. Let's get started!
I opened up the source code in Vim and made some changes I wanted. Then I tried to rebuild:
$ debuild
But I got the following error:
dh_clean: Compatibility levels before 5 are deprecated (level 4 in use)
dpkg-source -b gkrellweather-2.0.8
dpkg-source: warning: no source format specified in debian/source/format, see dpkg-source(1)
dpkg-source: info: using source format `1.0'
dpkg-source: info: building gkrellweather using existing gkrellweather_2.0.8.orig.tar.gz
dpkg-source: info: building gkrellweather in gkrellweather_2.0.8-2.diff.gz
dpkg-source: error: cannot represent change to gkrellweather-2.0.8/.gkrellweather.c.swp: binary file contents changed
dpkg-source: warning: the diff modifies the following upstream files:
GrabWeather
Makefile
gkrellweather.c
dpkg-source: info: use the '3.0 (quilt)' format to have separate and documented changes to upstream files, see dpkg-source(1)
dpkg-source: unrepresentable changes to source
dpkg-buildpackage: error: dpkg-source -b gkrellweather-2.0.8 gave error exit status 1
debuild: fatal error at line 1357:
dpkg-buildpackage -rfakeroot -D -us -uc failed
Why?
