The connect automatically option is allowed for my wired Wired connection 1. Disconnecting the connection works when I do it from the panel's Network > Disconnect menu. But when I do that with command:
nmcli con down id "Wired connection 1"
no sooner than it disconnects, the connection is back on.
How does Network > Disconnect work? Could we do the same with nmcli without disabling the automatic connection?
Note:
nmcli con down id "Wired connection 1"works as with automatic connection disabled (but again that's not an option),- I don't want to use
sudo(wouldn't be good to implement in a script!).
