I am trying to update my softwares but I get the following error:
The package system is broken
Check if you are using third party repositories. If so disable them, since they are a common source of problems.
Furthermore run the following command in a Terminal: apt-get install -f
linux-image-generic-lts-quantal: Depends: linux-image-3.5.0-45-generic but it is not installed***
After this, I tried installing the package linux-image-3.5.0-45-generic from the software center but I have the same dialog box as above stating that I have unmet dependencies and I need to install the very same package to install itself.
$ sudo apt-get install -f
[sudo] password for shashank:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
linux-image-3.5.0-47-generic linux-image-generic-lts-quantal
Suggested packages:
linux-lts-quantal-doc-3.5.0 linux-lts-quantal-source-3.5.0
linux-lts-quantal-tools linux-headers-3.5.0-47-generic
The following NEW packages will be installed:
The following packages will be upgraded:
1 upgraded, 1 newly installed, 0 to remove and 103 not upgraded.
4 not fully installed or removed.
Need to get 0 B/40.8 MB of archives.
After this operation, 158 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 224750 files and directories currently installed.)
Unpacking linux-image-3.5.0-47-generic (from .../linux-image-3.5.0-47-generic_3.5.0-47.71~precise1_amd64.deb) ...
Done.
dpkg: error processing /var/cache/apt/archives/linux-image-3.5.0-47-generic_3.5.0-47.71~precise1_amd64.deb (--unpack):
unable to create `/boot/abi-3.5.0-47-generic.dpkg-new' (while processing `./boot/abi-3.5.0-47-generic'): Read-only file system
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.5.0-47-generic /boot/vmlinuz-3.5.0-47-generic
run-parts: executing /etc/kernel/postrm.d/zz-runlilo 3.5.0-47-generic /boot/vmlinuz-3.5.0-47-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.5.0-47-generic /boot/vmlinuz-3.5.0-47-generic
And the output of uname -r shows,
$ uname -r
3.5.0-44-generic
I typed the command sudo mount in terminal and following is the output
shashank@shashank-HP-ProBook-445-G1:~$ sudo mount
/dev/sda6 on / type ext4 (rw,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
udev on /dev type devtmpfs (rw,mode=0755)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
/dev/sda1 on /boot type vfat (rw,errors=remount-ro)
/dev/sda5 on /home type ext4 (rw,errors=remount-ro)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,noexec,nosuid,nodev)
gvfs-fuse-daemon on /home/shashank/.gvfs type fuse.gvfs-fuse-daemon (rw,nosuid,nodev,user=shashank)
