new to Linux and am using Ubuntu 12.04 LTS. I'm having problems with the boot manager, as the GRUB2 menu is not allowing me to launch Windows 8. The Windows 8 Launcher option gives me this message every time I use it:
error: unknown command 'drivemap'.
error: invalid EFI file path.
Press any key to continue...
I have run boot-repair and that got the Ubuntu launcher working, but the problem with the Windows launcher in GRUB stays persistent. http://paste.ubuntu.com/7091293
Luis Alvarado
  • 216,643
Your install is UEFI.
It looks like you ran the 'buggy' UEFI in Boot-Repair. That is only required if you have a system that only boots Windows from UEFI menu.
To undo & to rename files to their original names, you just need to tick the "Restore EFI backups" option of Boot-Repair.
Also it looks like the only boot entry that will work currently is:
Windows UEFI bkpbootmgfw.efi
That is the renamed file that Boot-Repair renamed. If you undo the rename it will be without the bkp at beginning.
Boot-Repair also adds all the efi files that HP added as boot options. If you do not want those you have to edit 25_custom.
sudo cp -a /etc/grub.d/25_custom /etc/grub.d/bkup25_custom
gksudo gedit /etc/grub.d/25_custom
sudo update-grub
It also looks like os-prober is writing BIOS type entries that will not work.
oldfred
  • 12,583
Try
apt-get install os-prober && os-prober
Erikas
  • 681
