10
I set up a manually provisioned environment successfully (in local network among x3 12.04 ubuntu servers.) However adding the second machine failed twice. After the third try (installed missing dependency) their remained x2 'pending' machines.
I tried destroy-machines on those, than used destroy-environment to try and start over. Now when I add machine I get:
ERROR machine is already provisioned.
I have tried uninstalling/re-installing along with removing all juju files in ~/.juju.
Any ideas on how to start over or remove the provisioning?
Thanks!
ianmunoz
  • 299
Per documentation on https://jujucharms.com/docs/stable/clouds-manual:
Note: If you have an existing configuration, you can use juju generate-config --show to output the new config file, then copy and paste relevant areas in a text editor etc.
On each failing node:
sudo rm -rf /etc/init/juju*
sudo rm -rf /var/lib/juju
Now kill all Juju processes and run
sudo apt-get remove juju-mongodb landscape-common
sudo rm -rf /usr/lib/juju
sudo rm /tmp/pprof.jujud.* /usr/bin/juju-run
sudo rm -r /etc/juju
This will allow a normal add-machine.
Jorge Castro
  • 73,717
ianmunoz
  • 299
Ubuntu 18.04 with juju 2.6.8
Clean up the machine-node.
sudo rm -rf /lib/systemd/system/juju*
sudo rm -rf /run/systemd/units/invocation:juju*
sudo rm -rf /etc/systemd/system/juju*
Eliah Kagan
  • 119,640
Jonas
  • 61
Also, for newer systemd based distros: rm /etc/systemd/system/jujud*
Jorge Castro
  • 73,717
pppppp
