I recently installed Ubuntu 13.10 on my Toshiba P55 A5200 and everything was working perfectly. After I updated Ubuntu and installed a few applications GRUB menu won't show up and my computer only boots directly into Windows.
Your help is appreciated.
Eyob
  • 63
You can try reinstalling grub from within the live cd. Remember to replace 'sdX' with your desired boot disk/partition.
$ sudo grub-install /dev/sdX
$ sudo update-grub
If that fails try using boot-repair by following the steps below:
  1. Boot into your live cd.
  2. Download and install boot-repair (instructions here).
  3. Run from terminal: $ sudo boot-repair
  4. Select 'fix recommended'
  5. Reboot.
bleeves
  • 713
