After installing Ubuntu 12.04 on my system, Windows XP won't boot any more. Ubuntu starts ok however.
When starting Windows in the Grub menu, it give's an error:
ERROR: UNKNOWN FILESYSTEM.
GRUB RESCUE
I've tried to resolve it using boot-repair but with no result. Also tried the booterrorfix as suggested but no result.
Boot-repairs logs the following info:
http://paste.ubuntu.com/7079160/
Your support is much appreciated.
From the boot-repair log,
Grub2 (v1.99) is installed in the boot sector of sda1
and looks at sector 128708312 of the same hard drive
for core.img. core.img is at this location and looks
for (,msdos5)/boot/grub on this drive. No errors found
in the Boot Parameter Block.
Grub installed in the boot sector of dev/sda1 Windows Xp partition.So you have to repair your windows boot files and then you have to run boot-repair again.
See this to repair your Windows boot files and reinstall grub on /dev/sda disk.
Avinash Raj
  • 80,446
