Have found this question multiple times on the forum, but none of the answers were serious enough. So the problem with ubuntu 12.04. LTS server is that after a fresh install you can not install build-essential package. This is what you get:
Reading package lists...
Building dependency tree...
Reading state information...
 build-essential : Depends: libc6-dev but it is not going to be installed or
                            libc-dev
                   Depends: g++ (>= 4:4.4.3) but it is not going to be installed
Things that DON'T help:
apt-get clean
apt-get update
apt-get -f install
apt-get upgrade
dpkg --configure -a
apt-get autoclean
apt-get --fix-missing install build-essential
apt does say that I have "held broken packages", but none of the above commands solves them. After running any of the above commands the summary at the bottom is all zeros (upgraded, newly installed, remove, not upgraded)
uname -a gives:
Linux sorrg01lin 3.11.0-15-generic #25~precise1-Ubuntu SMP Thu Jan 30 17:42:40 UTC 2014 i686 i686 i386 GNU/Linux
lsb_release -a gives:
Distributor ID: Ubuntu
Description:    Ubuntu 12.04.4 LTS
Release:    12.04
Codename:   precise
Jorge Castro
  • 73,717
tom
  • 19
