107
I am using Ubuntu 12.04 LTS and I was wondering if there is a command that can tell the space used in a partition using the terminal. Like I want to use the su command to change to a user called admin (it is named admin). So I typed :
su admin
Entered the password
Now I want to see the disk space used in this partition. So.... Is there is a command fot that?
terdon
  • 104,119
Jatttt
  • 2,367
  • 33
  • 43
The su command is completely irrelevant. The disk usage is the same for all users. Anyway, some relevant commands and their output on my system are:
terdon@oregano ~ $ df -h
Filesystem            Size  Used Avail Use% Mounted on
/dev/sda7              68G   23G   43G  35% /
udev                   10M     0   10M   0% /dev
tmpfs                 800M  1.6M  798M   1% /run
tmpfs                 5.0M     0  5.0M   0% /run/lock
tmpfs                 3.2G   12M  3.2G   1% /run/shm
/dev/sda6             290G  256G   20G  94% /home
tmpfs                 3.2G  992K  3.2G   1% /tmp
none                  4.0K     0  4.0K   0% /sys/fs/cgroup
/dev/sdc1             466G  379G   88G  82% /media/terdon/Iomega_HDD
For a specific partition:
terdon@oregano ~ $ df -h /dev/sda7
Alternatively, though this only lists the size, not the %used:
terdon@oregano ~ $ lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda      8:0    0 465.8G  0 disk
├─sda1   8:1    0  39.2M  0 part
├─sda2   8:2    0  14.7G  0 part
├─sda3   8:3    0  78.1G  0 part
├─sda4   8:4    0     1K  0 part
├─sda5   8:5    0     2G  0 part
├─sda6   8:6    0 294.4G  0 part /home
├─sda7   8:7    0  68.7G  0 part /
└─sda8   8:8    0   7.8G  0 part [SWAP]
sdc      8:32   0 465.8G  0 disk
└─sdc1   8:33   0 465.8G  0 part /media/terdon/Iomega_HDD
sr0     11:0    1  1024M  0 rom
Conversely, you can use the du command to print directory size which will give you the disk usage of a partition if you run it on a partition's mountpoint: du -xsch /home for example. The -x option will "skip directories on different file systems," which is helpful if you have other mount points nested below the partition's mount point (typically /).
terdon
  • 104,119
38
You can use df -Th to get the used space of partitions:
$ df -Th
Filesystem     Type      Size  Used Avail Use% Mounted on
/dev/sda9      ext4       22G   16G  4.8G  77% /
none           tmpfs     4.0K     0  4.0K   0% /sys/fs/cgroup
udev           devtmpfs  1.5G  4.0K  1.5G   1% /dev
tmpfs          tmpfs     297M  1.4M  295M   1% /run
none           tmpfs     5.0M  4.0K  5.0M   1% /run/lock
none           tmpfs     1.5G  616K  1.5G   1% /run/shm
none           tmpfs     100M   68K  100M   1% /run/user
/dev/sda5      fuseblk    53G   34G   19G  65% /media/Songs
/dev/sda7      fuseblk   103G   90G   14G  88% /media/Data
/dev/sda6      fuseblk    69G   34G   35G  50% /media/Movies
/dev/sda1      fuseblk    49G   36G   14G  72% /media/guru/0C64A7F864A7E326
You can also provide it with a specific partition if you want to view disk utilization of only that partition:
$ df -Th /dev/sda9
You can also use pydf or discus to get better representation in terminal. You need to install these if you want to use it. Type:
sudo apt-get install pydf in terminal to install pydf.
$ pydf
/dev/sda9   22G  16G 4893M 72.7 [#########################.........] /
/dev/sda7  103G  90G   13G 87.2 [##############################....] /media/Data
/dev/sda6   69G  34G   35G 49.3 [#################.................] /media/Movies
/dev/sda5   53G  34G   19G 64.5 [######################............] /media/Songs
/dev/sda1   49G  35G   14G 71.9 [########################..........] /media/guru/0C64A7F864A7E326
g_p
  • 19,034
  • 59
  • 69
21
You can easily check disk space status with df -h.
Sometimes you might end up accidentally filling your hard disk via some automated processes you've set up. When that happened to me I needed to find where most of my disk space went. The following command was helpful for that task:
$ cd /
$ sudo du -sh ./*
This gives a list of files and folders in the current directory as well as the size of each one. If a directory is larger than it should be, cd to that directory and run sudo du -sh ./* again. Repeat until you've found what is using up most of your disk space.
Loknar
  • 311
