I need your help to run a bash script in crontab. As many other posts in askubuntu I'm facing the problem that a script that is properly running in terminal mode does not run in crontab. The error I get is:
/usr/local/rams60/build/fdgrib2/fdgrib2: error while loading shared libraries: libhdf5.so.8: cannot open shared object file: No such file or directory
Cron output also shows TERM environment variable not set.
but of course libhdf5.so.8 exists:
lrwxrwxrwx 1 root root 16 ene 20 12:54 /usr/local/hdf5/lib/libhdf5.so.8 -> libhdf5.so.8.0.1
I found some posts about similar issues like
Why crontab scripts are not working?
https://stackoverflow.com/questions/5064518/shell-script-and-cron-problems?rq=1
Following that posts I set PATH in my script adding both /usr/local/rams60/build/fdgrib2/ and /usr/local/hdf5/lib/
For sure I am missing some simple setting but I can't see where.
Thanks in advance for your help
