I have an AMD Raedon 6770 graphics card in my computer, and for some reason I'm unable to get Ubuntu 13.10 to read it. I had another copy of 13.10 on my desktop, but when I tried to install the .run file for the card from the terminal, it corrupted something within my operating system and I could no longer get Ubuntu to boot. I'm fairly new to this operating system, but am beginning to grasp the concept pretty fast. Is there anyway to add a library of screen resolutions? I really need something with a 16:9 ratio for my Emerson TV screen which I'm using as my monitor, and currently only 4:3 is available (linked tv to computer through a monitor cable).
I've also tried to run a few xrandr commands without any success. Any suggestions would be greatly appreciated!
If I understand correctly, you don't have a black screen, but rather are having trouble setting up the correct resolutions? If that's the case, then you should be able to follow this guide.
wyas
  • 171
Can you try this workaround to see if it helps?
$ sudo gedit /etc/defaults/grub &
In this file, find the line starting with GRUB_GFXMODE and set to to your screen resolution. For example, if your screen resolution is 1366x768, then,
GRUB_GFXMODE=1366x768
Save the file and close Text Editor. Then execute the following command and reboot to see if it works.
$ sudo update-grub2
If you choose to simply install the drivers after running the .run file rather than generating packages, you may have to run sudo aticonfig --initial and reboot.
In case you aren't aware, there is an easy way to install hardware drivers from Software Sources > Additional Drivers.
Try using the option while running the .run installer to create distribution-specific packages instead. That option will create three .debs, which you should install in this order by clicking the files:
  • fglrx_<version>-0ubuntu1_<architecture>.deb
  • fglrx-dev_<version>-0ubuntu1_<architecture>.deb
  • fglrx-amdcccle_<version>-0ubuntu1_<architecture>.deb
Or, with the terminal command: (assuming the .run file and thus resulting .deb files were directly in your home folder):
sudo dpkg -i fglrx*.deb
And reboot. It's a cleaner way to do things and shouldn't require configuration afterwards, except with dual-monitor scenarios and the like. But probably no terminal stuff.
If you use Kubuntu, you will also have to enable OpenGL detection in System Settings > Desktop Effects.
Richard
  • 8,588
