Before re-installing Ubuntu 12.04 LTS, I unmounted the /home directory. After a clean re-install, I recreated some of the users and installed the ubuntu-desktop package, then re-mounted the old /home directory. All of the documents have been restored, and I have no problem as long as I login with the shell. However, when I try to login to the GUI, it just re-loads the login screen. This has been happening ever since I included the old /home directory in /etc/fstab.
Trying to follow the solution here, I looked for the .Xauthority files in every user's /home directory and noticed something weird, the users seem to have been mixed up. For example, ls -lah | grep Xauthority in /home/bob would show as:
-rw------- 1 emily emily 53 Nov 29 10:19 .Xauthority
and so on. My guess is that I didn't re-create the users in the same order as in the old system, so that things went weird when I mounted the old /home directory. However! I need to be able to plug the old /home directory files as is because they are several TB and I don't have the space to transfer them here and there freely, nor am I allowed to delete anything. What should I do to fix this?
Is it a good idea to replace all hidden files in each old /home/user directory by the new ones?
[Additional information]
Contents of ls -l /home (after mounting old /home);
note: lost+found was NOT supposed to be an user.
total 36
drwxr-xr-x 22 bob bob 4096 Mar 11 12:23 alice
drwxr-xr-x 44 marc marc 4096 Mar 11 12:21 emily
drwxr-xr-x 23 1004 1004 4096 Jul 29 2013 bob
drwxr-xr-x 4 1005 1005 4096 Jul 30 2013 ken
drwx------ 2 root root 16384 Mar 27 2012 lost+found
drwxr-xr-r 40 emily emily 4096 Mar 11 12:49 marc
Contents of cat /etc/passwd (restricted to the users listed above):
root:x:0:0:root:/root:/bin/bash
marc:x:1000:1000:marc,,,:/home/marc:/bin/bash
emily:x:1001:1001:emily,,,:/home/emily:/bin/bash
bob:x:1002:1002:bob,,,:/home/bob:/bin/bash
ken:x:1003:1003:ken,,,:/home:ken:/bin/bash
Note: user alice was not re-created after OS re-install because the account was no longer needed.
Output of lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 931.5G 0 disk
+sda1 8:1 0 285M 0 part
+sda2 8:2 0 1K 0 part
+sda5 8:5 0 18.6G 0 part
+sda6 8:6 0 93.1G 0 part /home
+sda7 8:7 0 93.1G 0 part
+sda8 8:8 0 698.4G 0 part /home/marc/Data
+sda9 8:9 0 9.3G 0 part [SWAP]
+sda10 8:10 0 18.6G 0 part /
sr0 11:0 1 1024M 0 rom
sdb 8:16 0 1.8T 0 disk
+sdb1 8:17 0 1.8T 0 part /home/marc/Data2
sdc 8:32 0 1.8T 0 disk
+sdc1 8:33 0 200M 0 part
+sdc2 8:34 0 465.8G 0 part /home/marc/USB_Disk/Disk1
+sdc3 8:35 0 465.8G 0 part /home/marc/USB_Disk/Disk2
+sdc4 8:36 0 465.8G 0 part /home/emily/Data
+sdc5 8:37 0 465.6G 0 part /var/www
sdf 8:80 0 3.7T 0 disk
+sdf1 8:81 0 1.8T 0 part /home/ken
+sdf2 8:82 0 1.8T 0 part /home/bob
sde 8:64 1 29.8G 0 disk
+sde1 8:65 1 29.8G 0 part [SWAP]
As you can see, user marc has Documents shattered over a number of different disks and partitions.
