This answer is more generic because you don't give more info like if you run a mobile device and what drivers you are use.
First of all, check your module:
$ modinfo nvidia|grep -e Mobile
parm: NVreg_Mobile:int
On notebooks you should have set NVreg_Mobile=1.
$ cat /etc/modprobe.d/nvidia.conf
options nvidia NVreg_Mobile=1 NVreg_EnableMSI=1
and rebuild you initrd with update-initramfs -c -t -k all.
The MSI setting is generally good for memory copy with a fast interface.
$ grep nvidia /proc/interrupts
45: 3969293 0 PCI-MSI-edge nvidia
You should also use the lm-sensors package, which shows you the
system temperatures, voltages and fan speeds:
$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0: +43.0 C (high = +80.0 C, crit = +85.0 C)
Core 0: +40.0 C (high = +80.0 C, crit = +85.0 C)
Core 1: +42.0 C (high = +80.0 C, crit = +85.0 C)
pkg-temp-0-virtual-0
Adapter: Virtual device
temp1: +44.0 C
nct6775-isa-0290
Vcore: +0.98 V (min = +0.00 V, max = +1.74 V)
in1: +1.10 V (min = +0.00 V, max = +0.00 V) ALARM
AVCC: +3.33 V (min = +2.98 V, max = +3.63 V)
+3.3V: +3.33 V (min = +2.98 V, max = +3.63 V)
in4: +1.02 V (min = +0.00 V, max = +0.00 V) ALARM
in5: +1.04 V (min = +0.00 V, max = +0.00 V) ALARM
in6: +1.07 V (min = +0.00 V, max = +0.00 V) ALARM
3VSB: +3.38 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.31 V (min = +2.70 V, max = +3.63 V)
fan1: 1110 RPM (min = 0 RPM, div = 32) ALARM
fan2: 1028 RPM (min = 0 RPM, div = 32) ALARM
fan3: 562 RPM (min = 0 RPM, div = 32) ALARM
fan4: 0 RPM (div = 128)
SYSTIN: +34.0 C (high = +85.0 C, hyst = +75.0 C) sensor = CPU diode
CPUTIN: +35.0 C (high = +80.0 C, hyst = +75.0 C) sensor = CPU diode
PECI Agent 0: +43.5 C (high = +80.0 C, hyst = +75.0 C) sensor = Intel PECI
PCH_CHIP_TEMP: +49.0 C
PECI Agent 1: +0.0 C (high = +80.0 C, hyst = +75.0 C)
cpu0_vid: +0.000 V
intrusion0: OK
If you think your GPU-fan is to slow, and the particular fan is listed, then you can use the fancontrol tool to adjust it.
To read the temperature of you GPU use:
$ DISPLAY=:0 nvidia-settings -q GPUCoreTemp -n -t
51
