52
Wikipedia defines a hard link as:
a directory entry that associates a name with a file on a file system. (A directory is itself a special kind of file that contains a list of such entries.) The term is used in file systems which allow multiple hard links to be created for the same file.
I am wondering if the concept of hard link is equivalent to the Windows concept of Shortcut.
If hard links are not equivalent to shortcuts, then what's the closest Windows feature to hard links?
Computernerd
  • 1,401
5 Answers5
115
No, a hard link is completely different. A soft link is closer to a Windows shortcut (though there are important differences, symbolic links are more similar to windows shortcuts than hard links are). A hard link is a different thing and one you will almost never need.
Briefly, a soft link is created with this command:
ln -s foo bar
If you then run ls -l, you will see:
lrwxrwxrwx 1 terdon terdon 3 Mar 10 15:58 bar -> foo
-rw-r--r-- 2 terdon terdon 0 Mar 10 15:58 foo
The -> means that bar is a link to foo. So, opening bar, with a text editor for example, will actually open the separate file foo. However, deleting bar will just delete the shortcut, it will not affect the file foo.
Hard links, on the other hand, are created with this command:
ln foo bar
If you now run ls -l, there is no indication of any relationship between the files:
-rw-r--r-- 2 terdon terdon 0 Mar 10 15:58 bar
But—and this is very important—those are actually the same file. Files on Unix file systems are stored using inodes; an inode is basically the way the filesystem maps a file name to a particular location on the physical hard drive. So, hard links are files that point to the same inode as their target. Another way of putting this is that all files are actually hard links pointing to their inodes. Making a hard link to a file just creates a new pointer (file) on the file system that points to the same inode. Each inode can have multiple files pointing to it or one, or none.
To understand this more clearly, use ls -i which shows the inode associated with a file. Let's create a soft link and a hard link and see what happens:
ln -s foo SoftLinkToFoo
ln foo HardLinkToFoo
Now, check their inodes:
As you can see above, both foo and HardLinkToFoo have the same inode (16648029) while SoftLinkToFoo has a different one (16648036).
What happens if we rename foo with mv foo bar?
The red color indicates a broken soft link, one whose target can no longer be found. This is because soft links point to a file's name, not its inode. Note that despite changing the name, the inode remains the same so the hardlink is fine, it still works.
In summary, hard links are actually two manifestations of the same file; they are pointers to the same section of the disk. Soft links are just shortcuts. To take a real world analogy, hardlinks are like two different phone numbers for the same phone line and soft links are like having two different phone lines in the same house.
terdon
  • 104,119
18
There's a good explanation of what soft and hard links are, but one thing needs to be clarified.
Windows shortcuts are equivalent or similar to neither soft links nor hard links. On the file system level they are just files. It's the shell that understands their structure and interprets them as links. Windows shortcuts can also point to objects in shell namespaces which aren't related to the file system (printers, control panel items, virtual folders).
Windows shortcuts, in addition to the name of the file system object, contain the following information: PIDL (opaque binary "path" within shell namespace), description, hotkey, icon, working directory. Windows also adds NTFS object identifiers if NTFS file system is used, to fix broken shortcuts.
The rough equivalent of a Windows shortcut is a .desktop file. See this question on SuperUser: Is there an equivalent of .lnk in Linux?
Athari
  • 281
No. In Linux things work differently.
Each file is represented by an object called 'inode'. Every inode has a number (ID) associated with it.
As we know humans are not good at remembering numbers but names. (That's how phonebooks evolved)
Therefore, filename came into the picture to give each inode a human readable name. Basically, a hardlink binds a filename to an inode. An inode can have multiple hardlinks. If there are no hardlinks present for a particular inode, disk space used by the inode may be re-allocated for new files. Which means, at least one hardlink must present for each file. The filename (visualized as the filename/icon you see in file browser) itself is a hardlink.
In Windows, shortcut is a separate file (*.lnk file). It contains information about the original file (understandably the file path). In Linux perception, a Windows shortcut would be another inode hardlinked to a filename ending with '.lnk'.
A big difference , hard-link cannot be created for folders , but for files .
Shortcut can be created for folders , so you cannot say they are equivalent .
Your question should be the difference between symbolic link or soft link and shortcut .
as according to this:
A symbolic link is filesystem level, and everything sees it as the original file. An application needs no special support to use a symbolic link.
A "Shortcut" is just a regular file that has a reference to the destination file or directory .
So when you click a shortcut will change your directory to the actual file , while soft-link will refer to its location as if its the actual file , for that in Linux you can use terminal and cd to symbolic links while you cannot cd to shortcuts .
A Windows shortcut and a Linux launcher (pointing to some location) would be identical.
kamil
  • 7,397
nux
  • 39,152
On Windows you can create hardlinks too if you have NTFS filesystem.
fsutil hardlink create target_file source_file
The files has to be on the same logical drive.
Spook
  • 121
