I have recently installed Ubuntu 13.10 alongside Windows 7. The hibernate does not work from command prompt using sudo pm-hibernate, whereas the suspend works fine using sudo pm-suspend.
What could be the problem? How do I solve this?
Output of sudo fdisk -l:
Disk /dev/sda: 100.0 GB, 100030242816 bytes
255 heads, 63 sectors/track, 12161 cylinders, total 195371568 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xe0779162
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *          63   195366464    97683201    7  HPFS/NTFS/exFAT
Out put of cat /etc/fstab:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
/host/ubuntu/disks/root.disk /               ext4    loop,errors=remount-ro 0       1
/host/ubuntu/disks/swap.disk none            swap    loop,sw         0       0
Output of sudo blkid -o full -s UUID:
/dev/loop0: UUID="59cea3d6-37da-4a92-8ccf-f500a76750ff"
/dev/sda1: UUID="A4D4A3CAD4A39CD4"
jobin
  • 28,567
Hibernation is not supported for wubi installation. You will have to reinstall Ubuntu as a dual booted OS and then create a swap partition to enable hibernation.
Refer:
jobin
  • 28,567
