I tried sudo apt-get install ubuntu-restricted-extras on 13.10 and it all worked well until something named ttf-mscorefonts installer came. It was not getting downloaded for quite a few minutes. So I quit the process.
Now I am not able to install any software, not from software center. whenever I try with something like sudo apt-get install ****, it shows something like:
$ sudo apt-get install pip
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to   correct     the problem.
neel101@neel101-Inspiron-7520:~$ sudo dpkg --configure -a
Setting up update-notifier-common (0.147) ...
ttf-mscorefonts-installer: downloading http://downloads.sourceforge.net/corefonts/andale32.exe
and this continues for several minutes....
EDIT
I pressed Ctrl+C now and this came
^CTraceback (most recent call last):
  File "/usr/lib/update-notifier/package-data-downloader", line 296, in <module>
    process_download_requests()
  File "/usr/lib/update-notifier/package-data-downloader", line 234, in    process_download_requests
    dest_file = urllib.urlretrieve(files[i])[0]
  File "/usr/lib/python2.7/urllib.py", line 94, in urlretrieve
    return _urlopener.retrieve(url, filename, reporthook, data)
  File "/usr/lib/python2.7/urllib.py", line 268, in retrieve
    block = fp.read(bs)
  File "/usr/lib/python2.7/socket.py", line 380, in read
    data = self._sock.recv(left)
KeyboardInterrupt
dpkg: error processing update-notifier-common (--configure):
 subprocess installed post-installation script was interrupted
dpkg: dependency problems prevent configuration of ttf-mscorefonts-installer:
 ttf-mscorefonts-installer depends on update-notifier-common (>= 0.119ubuntu2);     however:
  Package update-notifier-common is not configured yet.
dpkg: error processing ttf-mscorefonts-installer (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of flashplugin-installer:
 flashplugin-installer depends on update-notifier-common (>= 0.119ubuntu2); however:
dpkg: error processing flashplugin-installer (--configure):
Zanna
  • 72,312
Try the below commands,
sudo apt-get autoremove
sudo apt-get clean
It will remove all the unused packages.
OR
sudo dpkg -P ttf-mscorefonts-installer
sudp dpkg -P flashplugin-installer
Avinash Raj
  • 80,446
