I wanted to modify my mount options for my NTFS external HDD so that I can execute programs on it. I added the following line to my fstab accordingly:
UUID=CE665A3F665A290B  /media/Josh  ntfs-3g defaults,users,nofail 0 0
But when I plug in my external and I get this error:
Error mounting: mount exited with exit code 1: helper failed with:
Error opening '/dev/sdb1': Permission denied
Failed to mount '/dev/sdb1': Permission denied
Please check '/dev/sdb1' and the ntfs-3g binary permissions, and the mounting user ID. More explanation is provided at http://tuxera.com/community/ntfs-3g-faq/#unprivileged.
Soo I go to the URL provided. It says:
Unprivileged block device mounts work only if all the below requirements are met:
  1. ntfs-3g is compiled with integrated FUSE support
  2. the ntfs-3g binary is at least version 1.2506
  3. the ntfs-3g binary is set to setuid-root
  4. the user has access right to the volume
  5. the user has access right to the mount point
I believe I have all 5 requirements met (though obviously not, since I'm getting that error). Anyone have some tips? In particular, I have:
  1. ntfs-3g 2014.2.15 integrated FUSE 27
  2. ntfs-3g 2014.2.15 integrated FUSE 27
  3. -rwsr-xr-x 1 root root 504887 Mar 8 12:06 /bin/ntfs-3g*
  4. brw-rw---- 1 root disk 8, 17 Mar 8 16:43 /dev/sdb1 (my user is in the "disk" group)
  5. drwxrwxrwx 2 josh josh 4096 Mar 8 12:42 Josh/
Been struggling with this for hours. This link has been the most helpful so far, but notably the last post has my same question and is unanswered.
Thanks!
jwayne
  • 141
Found an answer that lets me not edit my fstab to get what I want. Since my disk gets automounted, I added a rule to my udev that told the automount to do something special upon plug-in (that I don't really understand). But now my disk gets automounted with all files executable. I created a file /etc/udev/rules.d/99-usb-disks.rules and added:
ENV{ID_FS_TYPE}=="ntfs", ENV{ID_FS_TYPE}="ntfs-3g"
Source: http://ubuntuforums.org/showthread.php?t=1914416&p=11636662#post11636662
Still haven't found a way to get rid of my permissions error when I do use my fstab mod, though.
Thanks terdon for the help.
jwayne
  • 141
