15
I just downloaded the GTA SA.. and it works fine with the SA:MP 0.3z RC2, but I have a big problem. There is a server which uses a secondary client. I tried to run it with WINE and Mono, but it still doesn't work. By the way, it needs .NET 2.0 on Windows, but I can't make it work on Ubuntu 12.04.
This is the client program:
http://data.hu/get/7493141/ClassRPG.exe
Error message when run by Wine:
wine: Install Mono for Windows to run .NET 2.0 applications.
Error message when run by Mono:
The entry point method could not be loaded.
Any ideas?
Braiam
  • 69,112
type this in your terminal:
sudo apt-get install mono-vbnc
mono ~/Downloads/ClassRPG.exe
assuming you downloaded the file in your home download directory and it is named ClassRPG.exe
kamil
  • 7,397
If the application in question is pure .Net and compatable with Mono, simply run:
sudo apt-get install mono-complete
Then run it from mono.
If not, you can use winetricks to install Mono or .Net in order to run it.
For .Net you need to be running a 32bit Wine bottle, but for wine-mono or mono you can run it on 64bit or 32bit
