I was trying to install virtualbox-guess-additions-iso, and got the following error:
sudo aptitude install virtualbox-guest-additions-iso
The following NEW packages will be installed:
libgsoap1{a} virtualbox{a} virtualbox-dkms{a} virtualbox-guest-additions-iso
virtualbox-qt{a}
0 packages upgraded, 5 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/64.0 MB of archives. After unpacking 121 MB will be used.
virtualbox-4.3 : Conflicts: virtualbox but 4.1.12-dfsg-2ubuntu0.5 is to be
installed.
              Conflicts: virtualbox-guest-additions-iso but 4.1.12-1 is to be
installed.
The following actions will resolve these dependencies:
   Remove the following packages:
1)     virtualbox-4.3
Accept this solution? [Y/n/q/?] y
   virtualbox-qt{a}
The following packages will be REMOVED:
   virtualbox-4.3{a}
0 packages upgraded, 5 newly installed, 1 to remove and 0 not upgraded.
Need to get 0 B/64.0 MB of archives. After unpacking 33.0 MB will be freed.
Do you want to continue? [Y/n/?] y
(Reading database ... 484051 files and directories currently installed.)
Removing virtualbox-4.3 ...
dpkg: error processing virtualbox-4.3 (--remove):
  subprocess installed pre-removal script returned error exit status 1
No apport report written because MaxReports is reached already
                                                          Errors were encountered
while processing:
  virtualbox-4.3
A package failed to install.  Trying to recover:
Looks like you're running VirtualBox 4.3 but the PPA for VirtualBox in the Ubuntu repositories is pulling an older version 4.1.12.
If you want to install the virtual box guest additions for the proper version of VirtualBox you're running I'd suggest using the Virtual Box Manager menu option.
