The bash terminal commands history for a user is stored in $HOME/.bash_history file. The commands used in the tty session will be written to the .bash_history file when the tty session is terminated; but running history -c command will prevent them from being appended in the history file. What history command does is it displays the contents of the $HOME/.bash_history. (You can also check and/or edit the file with text editors, say with nano $HOME/.bash_history.)
"A command with a space before it won't be stored.., !! or duplicate commands won't be stored, etc."
You can change the settings according to your needs by making changed in $HOME/.bashrc file. This post explains how: Get bash history to remember only the commands run with space prefixed!.
And in this file you may find lines like:
# for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
HISTSIZE=1000
HISTFILESIZE=2000
HISTSIZE is the number of commands to remember in the command history. The default value is 500.
HISTFILESIZE is maximum number of lines contained in the history file. When this variable is assigned a value, the history file is truncated, if necessary, by removing the oldest entries, to contain no more than that number of lines. The default value is 500. The history file is also truncated to this size after writing it when an interactive shell exits.
So, to summarize history -c just clears the running tty session's history and the previous commands should still be accessible with history command provided the older commands are not truncated as per the HISTFILESIZE <= max_lines constraint.
