22
Is it possible to force apt-get to download a multi-architecture binary of the library I want to install?
Or is apt-get not the right tool for this?
radj
  • 725
@Tanasis's answer is correct, I have updated it for 2021 (Ubuntu 20.04 LTS) for arm64 and armhf.
  1. Add your desired architectures as follows:
    sudo dpkg --add-architecture armhf
    sudo dpkg --add-architecture arm64
  2. Create a new .list file in /etc/apt/sources.list.d:
    sudo touch /etc/apt/sources.list.d/arm-cross-compile-sources.list
  3. Add the default sources to that list with the architectures (armhf, arm64) prefixed as such:
    deb [arch=armhf,arm64] http://ports.ubuntu.com/ focal main restricted
    deb [arch=armhf,arm64] http://ports.ubuntu.com/ focal-updates main restricted
    deb [arch=armhf,arm64] http://ports.ubuntu.com/ focal universe
    deb [arch=armhf,arm64] http://ports.ubuntu.com/ focal-updates universe
    deb [arch=armhf,arm64] http://ports.ubuntu.com/ focal multiverse
    deb [arch=armhf,arm64] http://ports.ubuntu.com/ focal-updates multiverse
    deb [arch=armhf,arm64] http://ports.ubuntu.com/ focal-backports main restricted universe multiverse
  4. Update /etc/apt/sources.list to include your default architecture (if it doesn't already), otherwise apt will try to use your newly added architectures in those sources which may cause errors as it did with me. Add [arch=amd64] for each line in /etc/apt/sources.list as follows:
    deb [arch=amd64] http://us.archive.ubuntu.com/ubuntu/ focal main restricted universe multiverse
  5. Run sudo apt update and make sure you get no errors
  6. Installing a package with the new architectures should be successful now:
    sudo apt install libasound2-dev:arm64
First to enable multi-arch
dpkg --add-architecture <arch>
Now setup apt-sources to add the new repositories of the new architecture(if you need)
now update your sources.list
sudo apt-get update
Now you can install multi-arch packages via apt-get regularly but you have to specify which architecture you want to download
apt-get install package:architecture
example:
apt-get install gedit:i386
Maythux
  • 87,123
For arm64 I am doing the following on the /etc/apt/sources.list:
Ubuntu 16.04 (xenial) example:
I mark all the current (default) repos as [arch=<current_os_arch>], e.g.
deb [arch=amd64] http://archive.ubuntu.com/ubuntu/ xenial main restricted
And I added the following:
deb [arch=arm64] http://ports.ubuntu.com/ xenial main restricted
deb [arch=arm64] http://ports.ubuntu.com/ xenial-updates main restricted
deb [arch=arm64] http://ports.ubuntu.com/ xenial universe
deb [arch=arm64] http://ports.ubuntu.com/ xenial-updates universe
deb [arch=arm64] http://ports.ubuntu.com/ xenial multiverse
deb [arch=arm64] http://ports.ubuntu.com/ xenial-updates multiverse
deb [arch=arm64] http://ports.ubuntu.com/ xenial-backports main restricted universe multiverse
Not sure if this is the corrent fix, but at least it seems to be working.
Note: Don't forget to add foreign architecture: dpkg --add-architecture arm64
Tanasis
  • 516
Ok I need this too for my docker image. The strange thing is for amd64 it works but not for arm64
Start of the docker image
FROM --platform=$TARGETPLATFORM mcr.microsoft.com/dotnet/aspnet:8.0-jammy AS base
COPY --from=mcr.microsoft.com/dotnet/sdk:6.0 /usr/share/dotnet/shared /usr/share/dotnet/shared
ENV DOTNET_NUGET_SIGNATURE_VERIFICATION=false
Set TARGETPLATFORM for multi-platform compatibility
ARG TARGETARCH ARG TARGETPLATFORM ARG BUILD_CONFIGURATION WORKDIR /app EXPOSE 80 EXPOSE 443
RUN dpkg --add-architecture $TARGETARCH RUN apt-get update RUN apt install -y libc6:$TARGETARCH RUN apt install -y libicu-dev:$TARGETARCH RUN apt install -y libfontconfig1:$TARGETARCH
