I'm trying to get all my data at this point. Any help? Once and a while it will mount but cant get data off quickly.
Error Message:
Error mounting /dev/sdb1 at /media/ubuntu/Elements: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=999,gid=999,dmask=0077,fmask=0177" "/dev/sdb1" "/media/ubuntu/Elements"' exited with non-zero exit status 21: fuse: mount failed: Device or resource busy
 (udisks-error-quark, 0)
~$ lsusb
Bus 002 Device 002: ID 064e:a103 Suyin Corp. Acer/HP Integrated Webcam [CN0314]
Bus 002 Device 003: ID 1058:1042 Western Digital Technologies, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
sudo fdisk -l
Disk /dev/sda: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142448 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x64befb2b
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1            2048    24578047    12288000   27  Hidden NTFS WinRE
/dev/sda2   *    24578048    24782847      102400    7  HPFS/NTFS/exFAT
/dev/sda3        24782848   625139711   300178432    7  HPFS/NTFS/exFAT
Disk /dev/sdb: 1000.2 GB, 1000202043392 bytes
255 heads, 63 sectors/track, 121600 cylinders, total 1953519616 sectors
Disk identifier: 0x0002846e
/dev/sdb1            2048  1953519615   976758784    7  HPFS/NTFS/exFAT
nux
  • 39,152
I faced a similar problem. Here is my workaround:
  1. Create folder /media/wd-elements
  2. Find out UUID of your external disk: sudo blkid
  3. Add following line to your /etc/fstab: UUID=<UUID> /media/wd-elements ntfs-3g defaults,soft,_netdev,users 0 0
  4. Setup rule to mount your disk when it is plugged. link
If anyone has a better solution, share it please.
EDIT: I installed new version of Ubuntu (14.04) and my external disk mounts and unmounts correctly now!
Try rebooting the computer with the drive plugged in. I'd given up on using the drive with Ubuntu and purely by chance I'd left the drive plugged in when I rebooted. It's never shown up when I've plugged it in while booted up but showed up immediately after a reboot. It's a 1TB WD USB 3.0 drive.
