I am trying to change the power profile on my ATI Mobility Radeon HD 4530 in order to prevent overheating.
I'm following instructions which say to do the following:
sudo sh -c "echo profile > /sys/class/drm/card0/device/power_method"
sudo sh -c "echo mid > /sys/class/drm/card0/device/power_profile "
However when I try and run this I get the following error
sh: 1: cannot create /sys/class/drm/card0/device/power_method: Directory nonexistent
How can I change the power profile so my laptop doesn't overheat?
trampster
  • 11,792
The problem was that the AMD Catalyst driver was still installed, the system wasn't using it because my card is no longer supported, however it was still installed and this was in some way preventing /sys/class/drm from being there.
I uninstalled the AMD Catalyst driver and rebooted and after that I could change the power profile.
The good news is after running that command my temp dropped 15 degrees.
trampster
  • 11,792
