Can you tell me what the difference is between cat and sudo cat?
All I know so far is that cat is used for displaying contents of file and concatenation.
Braiam
  • 69,112
Edison
  • 367
For a little humour I would say that cat is an animal and sudo cat is a feline with superpowers. :D
sudo is a command that you use to obtain root privileges. root is a special user that manages the machine, and for this he/she has superpowers. For example, if there is a file that only root can see its contents, and you are logged in as a normal user, you can use
$ sudo cat name_of_the_file
to read it. Also if there is a program that only root can run, like the reboot command:
$ reboot
warning: must be root!
$ sudo reboot
rebooting...........
THE CATCH IS: you must be specially (and manually) assigned by root to have permission to use sudo. The permission is given in a file called /etc/sudoers. In Ubuntu, the first user, the one created during install, is automatically a sudoer. But the subsequent users are not. You have to add them manually to the group sudo whose members are allowed to use the command sudo.
By the way, /etc/sudoers is a file that only root can see. So if you do
$ cat /etc/sudoers
you will not be able to see its contents. But if you do:
$ sudo cat /etc/sudoers
you are good.
Hope this helps.
guntbert
  • 13,475
Henrique
  • 701
Cat is a standard unix utiliy and a most frequently used command which concatenate files and print on the standard output.
You may open a terminal (press CTRL+ATL+T) & type man cat to know more about the command and its usage.
Further, the difference between cat & using sudo cat;
  • cat - Frequently & the standard command in use to print an output
  • sudo cat - Which prints an output with root privilege. This is mostly needed when a file doesn't have read access for certain user/users but not limited to root user.
Example;
-rw------- 2 root root 4096 996 Feb  6 20:39 log.txt
Above seen is a file which only a root user (or a user who's within root group) can read/write. In such situation you will need to use sudo cat filename to print the output.
Assume it helped you to understand more.!
AzkerM
  • 10,390
cat is used to read a file; sudo is used for super user privileges. So sudo cat means read the file with super user (that is, root) privileges.
TRiG
  • 2,006
Qasim
  • 22,162
