I have 2 options of VGA:
lspci | grep VGA
00:02.0 VGA compatible controller: Cirrus Logic GD 5446
00:03.0 VGA compatible controller: NVIDIA Corporation GK104GL [GRID K520] (rev a1)
It's an instance of Ubuntu running on Amazon EC2.
When I open my xserver I get the following message:
(WW) CIRRUS: More than one matching Device section found: Autoconfigured Video Device cirrus
In fact the X server gets open and it works. But with the resources of the "Cirrus Logic". I wanna be able to choose the VGA I want when open the X Server. How do I do that?
  • PS: The final goal here is to use OpenGL of NVIDIA. This is an Ubuntu running on Amazon AWS. It has GPU so it's supposed to have a way for me to use OpenGL on it.
  • PS2: Disable the Cirrus VGA is also very welcome. Is there a way to do that?
So I got everything to run on the Amazon-provided Ubuntu 14.04 AMI ubuntu-trusty-14.04-amd64 . Below is my setup code. I kept the old answer attached below as well, for people to find in Google.
    # setup kernel
    sudo apt-get update
    sudo apt-get install -y gcc make linux-generic
    # install X server and OpenGL tools
    sudo apt-get install -y xserver-xorg mesa-utils
    # disable Nouveau
    # via http://altinukshini.wordpress.com/2011/07/28/how-to-install-nvidia-drivers-in-ubuntu-linux/
    sudo echo 'blacklist nouveau' >> /etc/modprobe.d/blacklist.conf
    sudo echo 'options nouveau modeset=0' >> /etc/modprobe.d/blacklist.conf
    echo options nouveau modeset=0 | sudo tee -a /etc/modprobe.d/nouveau-kms.conf
    sudo update-initramfs -u
    # reboot to get kernel update and nouveau disabling activated
    sudo reboot now
    # install NVIDIA drivers
    # version was chosen because was "Latest Long Lived Branch version", which sounds stable
    # resources:
    #   http://docs.aws.amazon.com/AWSEC2/latest/UserGuide/using_cluster_computing.html
    #   http://www.nvidia.com/object/unix.html
    #   http://us.download.nvidia.com/XFree86/Linux-x86_64/340.46/README/index.html
    wget http://us.download.nvidia.com/XFree86/Linux-x86_64/340.46/NVIDIA-Linux-x86_64-340.46.run
    sudo /bin/bash ./NVIDIA-Linux-x86_64-340.46.run --accept-license --no-questions --ui=none
    sudo reboot now
    # setup xorg.conf
    # via https://stackoverflow.com/questions/19856192/run-opengl-on-aws-gpu-instances-with-centos
    sudo nvidia-xconfig -a --use-display-device=None --virtual=1280x1024
    # add missing BusID
    sudo sed -i 's/    BoardName      "GRID K520"/    BoardName      "GRID K520"\n    BusID          "0:3:0"/g' /etc/X11/xorg.conf
    # run x server and glxgears as test application
    sudo /usr/bin/X &
    DISPLAY=:0 glxgears
Old Post
Sadly I haven't found the answer myself yet, but here is some breadcrumbs on the way:
I installed the NVIDIA drivers
# from aws docs http://docs.aws.amazon.com/AWSEC2/latest/UserGuide/using_cluster_computing.html
sudo apt-get update
sudo apt-get install -y linux-generic
sudo reboot now
wget http://us.download.nvidia.com/XFree86/Linux-x86_64/343.22/NVIDIA-Linux-x86_64-343.22.run
sudo /bin/bash ./NVIDIA-Linux-x86_64-343.22.run
sudo reboot now
(if you get an error because of nouveau drivers, check here)
Next install XServer
And generate the xconfig (as per other stack overflow question)
Weirdly this generates a file in /etc/X11/XF86Config, so I copied that to /etc/X11/xorg.conf, in order for X to pick it up.
Now running the Xserver gives the following error for me:
sudo /usr/bin/X :0 &
(WW) CIRRUS: No matching Device section for instance (BusID PCI:0@0:2:0) found
One answer in that stack overflow question says to choose the bus, which results in this error:
error setting MTRR (base = 0xe8000000, size = 0x00100000, type = 1) Invalid argument (22)
Whatever that means. Looking back at the log reveals, that apparently the NVIDIA driver is not loaded at all (although tried):
cat /var/log/Xorg.0.log
[  3136.163] Loading extension GLX
[  3136.163] (II) LoadModule: "nvidia"
[  3136.164] (WW) Warning, couldn't open module nvidia
[  3136.164] (II) UnloadModule: "nvidia"
[  3136.164] (II) Unloading nvidia
[  3136.164] (EE) Failed to load module "nvidia" (module does not exist, 0)
Now this post suggests, that the module path has to be set manually in the conf:
# find the path (maybe)
sudo find / | grep nvidia | grep modules
usr/X11R6/lib/modules/
# put it into the conf file
vim /etc/X11/xorg.conf
Section "Files"
     ModulePath     "/usr/X11R6/lib/modules"
EndSection
Anyways, this seems to actually load the driver module and then crashes:
(EE)
(EE) Backtrace:
(EE) 0: /usr/bin/X (xorg_backtrace+0x48) [0x7f65c7ea9d28]
(EE) 1: /usr/bin/X (0x7f65c7d01000+0x1aca19) [0x7f65c7eada19]
(EE) 2: /lib/x86_64-linux-gnu/libpthread.so.0 (0x7f65c6dfe000+0x10340) [0x7f65c6e0e340]
(EE) 3: /usr/X11R6/lib/modules/drivers/nvidia_drv.so (0x7f65bf75b000+0x88cb5) [0x7f65bf7e3cb5]
(EE) 4: /usr/X11R6/lib/modules/drivers/nvidia_drv.so (0x7f65bf75b000+0x69272) [0x7f65bf7c4272]
(EE) 5: /usr/X11R6/lib/modules/drivers/nvidia_drv.so (0x7f65bf75b000+0x55e43a) [0x7f65bfcb943a]
(EE) 6: /usr/bin/X (0x7f65c7d01000+0xaf67b) [0x7f65c7db067b]
(EE) 7: /usr/bin/X (xf86CallDriverProbe+0x5e) [0x7f65c7d89a5e]
(EE) 8: /usr/bin/X (xf86BusConfig+0x46) [0x7f65c7d8a3d6]
(EE) 9: /usr/bin/X (InitOutput+0x993) [0x7f65c7d982b3]
(EE) 10: /usr/bin/X (0x7f65c7d01000+0x596bb) [0x7f65c7d5a6bb]
(EE) 11: /lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main+0xf5) [0x7f65c583dec5]
(EE) 12: /usr/bin/X (0x7f65c7d01000+0x44dde) [0x7f65c7d45dde]
Freenerd
  • 131
