I am working on expanding a currently attached volume to one of my Ubuntu Amazon AWS servers, but I am having some problems. I already created a new volume from a snapshot, then attached the newly created volume to the EC2 instance. I prepare the volume for use by the following commands:
sudo vgchange -a y
sudo cryptsetup luksOpen /dev/mapper/vgdata2-lvdata cryptmnt
This volume was originally 600GB and is now 700GB. After mounting the volume with
sudo mount /dev/mapper/cryptmnt /mnt/ebs1
I try to expand the volume using
sudo xfs_growfs -d /mnt/ebs1/
Which results in this output
meta-data=/dev/mapper/cryptmnt   isize=256    agcount=4, agsize=39321280 blks
         =                       sectsz=512   attr=2
data     =                       bsize=4096   blocks=157285119, imaxpct=25
         =                       sunit=0      swidth=0 blks
naming   =version 2              bsize=4096   ascii-ci=0
log      =internal               bsize=4096   blocks=76799, version=2
         =                       sectsz=512   sunit=0 blks, lazy-count=1
realtime =none                   extsz=4096   blocks=0, rtextents=0
data size unchanged, skipping
I have no idea if I'm doing something wrong or if there are steps that I am missing. Running df -h after this results in the following output
Filesystem            Size  Used Avail Use% Mounted on
/dev/sda1             7.9G  4.8G  2.7G  65% /
none                  827M  124K  827M   1% /dev
none                  833M     0  833M   0% /dev/shm
none                  833M   52K  833M   1% /var/run
none                  833M     0  833M   0% /var/lock
/dev/mapper/cryptmnt  600G  598G  2.3G 100% /mnt/ebs1
Which shows that the volume was not resized.
Braiam
  • 69,112
BLenau
When resizing a volume, you need to resize all the layers, starting from the bottom up.
In this case you have 6 layers:
  • EC2 volume
  • LVM physical volume
  • LVM volume group (automatic upon resizing the physical volume)
  • LVM logical volume
  • LUKS volume
  • XFS filesystem
In this case "bottom" means the first one
Resize the LVM physical volume:
pvresize /dev/xvdH
(replace with the actual device path)
Resize the logical volume
lvresize -l +100%FREE vgdata2-lvdata
(adjust to how much space you want the volume to use if not 100%)
Resize the luks volume
cryptsetup resize /dev/mapper/cryptmnt
Resize the filesystem
xfs_growfs /mnt/ebs1
phemmer
  • 179
