I'd like to be able to stream music, realtime, to a friend. Not in my LAN, but over the internet. I've done a lot of research on how to do this, one option was setting up a shoutcast server, but that isn't realtime as far as I know. VLC allows streaming, but again, this is not realtime.
I can't imagine this being so hard to do. I did a lot of research, and the "best" solution I could find was to use teamspeak with a music player plugin. It would be soo much more convenient though if I could just open rythmbox and start a stream, in which someone else could join and listen.
Seth
  • 59,332
I don't know much about the subject but if you want to use rhythmbox, perhaps this might be interesting:
rhythmbox-ampache and ampache
The Music Player Daemon or short MPD is an excellent choice for streaming audio to other computers or even mobile devices, like phones/mp3-players, that are connected with the net.
MPD is designed around a client/server architecture, where the clients and server (MPD is the server) interact over a network. Thus, running MPD is only half of the equation. To use MPD, you need to install a MPD client (aka MPD interface). Command-line Clients
You can choose between a terminal or graphical based interface clients:
  • mpc - a solid, lightweight, simple mpd client, written in C. Console Clients
  • ncmpc - A curses client written in C.
  • ncmpcpp - A curses client written in C++ tailored after ncmpc. Graphical Clients
  • gmpc (Gnome Music Player Client) - A fully featured client.
  • ario - Another GTK based client.
  • More clients can be found on the Wiki
Ubuntu Install Procedure:
  1. First, edit /etc/apt/sources.list and enable the 'universe' repository. After you make this change, you will have to run apt-get update. You can use Synaptic. If for some reason this installation fails, this howto on the Ubuntu Forums may help, or the user-manual.
sudo apt-get update
sudo apt-get install mpd
OR
  1. If you just need only MP3 and FLAC support through ALSA, then you can compile it from source:
download the latest sources
extract them to some directory (for example 'mpd-x-x-x')
go to this directory (for example 'cd mpd-x-x-x')
install the dependencies, compile and install:
 sudo apt-get update
 sudo apt-get install libasound2-dev libmad0-dev libid3tag0-dev libflac-dev libflac++-dev libglib2.0-dev
./configure
make
sudo make install
v2r
  • 9,707
You can use MPD .It has capability to steam music.
If you want to stream audio from mpd to another computer , edit /etc/mpd.conf on the server running mpd to use the IP address of the target computer and /etc/pulse/default.pa or $XDG_CONFIG_HOME/default.pa(typically ~/.config/pulse/default.pa) on the target computer using the IP address of the server.
For more see here. wiki.archlinux.org
g_p
  • 19,034
  • 59
  • 69
