I reviewed this, and I'm familiar with wlan device disappear (BCM43142) although it seems that the wireless adapter is installed (claimed) correctly, I'm unable to discover all wireless network in range, it only discovers a few.
enclosed a snippet of my machine configuration
$ cat /etc/*release* | grep -i distrib
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=13.10
DISTRIB_CODENAME=saucy
DISTRIB_DESCRIPTION="Ubuntu 13.10"
$ lspci | grep -i bcm
01:00.0 Network controller: Broadcom Corporation BCM43142 802.11b/g/n (rev 01)
$ lshw -c network
*-network
description: Wireless interface
product: BCM43142 802.11b/g/n
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: eth3
version: 01
serial: c0:18:85:bc:70:ef
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=wl0 driverversion=6.30.223.141 (r415941) latency=0 multicast=yes wireless=IEEE 802.11abg
resources: irq:16 memory:d0500000-d0507fff
*-network
description: Ethernet interface
product: AR8161 Gigabit Ethernet
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth2
version: 10
serial: 84:8f:69:d4:38:f8
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=alx duplex=full ip=192.168.1.105 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:45 memory:d0400000-d043ffff ioport:2000(size=128)
$ lsmod | grep -i "bcm\|wl"
bcma 46699 0
wl 4207760 0
lib80211 14381 2 wl,lib80211_crypt_tkip
cfg80211 480503 2 wl,mac80211
$ ifconfig
eth0 Link encap:Ethernet HWaddr 84:8f:69:d4:38:f8
inet addr:192.168.1.105 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::868f:69ff:fed4:38f8/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:16
eth1 Link encap:Ethernet HWaddr c0:18:85:bc:70:ef
inet6 addr: fe80::c218:85ff:febc:70ef/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
Interrupt:16
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:78 errors:0 dropped:0 overruns:0 frame:0
TX packets:78 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:11043 (11.0 KB) TX bytes:11043 (11.0 KB)
$ dmesg | grep -i bcm
[ 2.135729] usb 2-1.5: Product: BCM43142A0
[ 17.274440] eth1: Broadcom BCM4365 802.11 Hybrid Wireless Controller 6.30.223.141 (r415941)
any help will be appreciated!
update
i also tried the following, but the problem still holds:
$ sudo dpkg-reconfigure bcmwl-kernel-source
and even
$ sudo apt-get autoremove bcmwl-kernel-source
$ sudo apt-get --purge remove bcmwl-kernel-source
$ sudo apt-get install bcmwl-kernel-source
update 2
i even tried to search for any documentation of bcm43142 over linux wireless wiki. surprisingly, there was only one record, which says "unsupported". can it be that the driver, which i am currently using, is detecting only 802.11n, and neither 802.11a/b/g?
update 3
i found a generic driver source from broadcom, and followed the installation manual. but it seems that there is a problem compiling the driver under kernel version 3.10 and above. to check the kernel version execute
$ uname -r
3.11.0-17-generic
searching around, i found a patch to fix the issue. applying it, let make complete successfully.
$ make
KBUILD_NOPEDANTIC=1 make -C /lib/modules/`uname -r`/build M=`pwd`
make[1]: Entering directory `/usr/src/linux-headers-3.11.0-17-generic'
CFG80211 API is prefered for this kernel version
Using CFG80211 API
LD /tmp/wlan/built-in.o
CC [M] /tmp/wlan/src/shared/linux_osl.o
CC [M] /tmp/wlan/src/wl/sys/wl_linux.o
CC [M] /tmp/wlan/src/wl/sys/wl_iw.o
CC [M] /tmp/wlan/src/wl/sys/wl_cfg80211_hybrid.o
LD [M] /tmp/wlan/wl.o
Building modules, stage 2.
Using CFG80211 API
MODPOST 1 modules
WARNING: modpost: missing MODULE_LICENSE() in /tmp/wlan/wl.o
see include/linux/module.h for more information
WARNING: modpost: Found 1 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y'
CC /tmp/wlan/wl.mod.o
LD [M] /tmp/wlan/wl.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.11.0-17-generic'
though i am not sure if i should execute make install, since i am not sure of the out come and i really do not want it to break my system.
any advise?
