I just got a new laptop: Dell Inspiron 17 (3737) BTX Base. The graphic card is IntelĀ® HD Graphics 4400
I installed Ubuntu 13.10.
The graphics are just horrible. It looks like an old 4 bits color display or something.
I ran the system testing tool and I got the following results:
graphics/driver_version FAILED ERROR: No video driver loaded! Possibly in failsafe mode!
It looks like the video driver is not installed properly. How can I fix this?
Here is some additional info:
lspci -nn | grep VGA
00:02.0 VGA compatible controller [0300]: Intel Corporation Haswell-ULT Integrated Graphics Controller [8086:0a16] (rev 09)
I also tried the Intel Graphics Installer, but nothing changed. Still stuck with the same problem.
Thanks,
Mitch
  • 109,787
Well, my identical machine does the same (inspiron 17 3737 - processor i3-4010U with hd4400). The RGB signal is all messed up.
Weirdly enough , when I connect a display on the HDMI port, that one works fine.
If you only need 1 display, and not much graphics : boot with NOMODESET (procedure to do this can be found here ).
Otherwise : Ubuntu 12.04, 13.04, 13.10, daily 14 do not solve the problem, with or without update, with or without the 1.0.3 or 1.0.4 Intel drivers from Intel 01.org
It's an intel chipset so there are no proprietary drivers to install, just the mesa open source drivers from intel.
Type this in a terminal (ctrl+alt+t) :
sudo apt-get install xserver-xorg-video-intel
and that should install the driver.
You could also download the intel driver installer from here :
https://01.org/linuxgraphics/downloads/2014/intelr-graphics-installer-1.0.4-linux
