https://stackoverflow.com/questions/9131763/eclipse-cdt-c11-c0x-support
I come from that website.
I have a C++ project that compiles with g++-4.8 without problems. I just wanted to use std::int8_t from the cstdint file.
Problem is the eclipse indexer can't resolve the name.
I went to the csdint file and in the initial macro it expands __cplusplus to 199711L instead of 201103L.
In my project settings I added std=c++11 and in the compiler flags I addded GXX_EXPERIMENTAL_CXX0X
And did I say it compiles?
It's very frustrating, I suppose I can live without the indexer, but then again what is the purpose of an IDE if it's giving me error false positives.
I found my answer in here: http://www.eclipse.org/forums/index.php/t/490066/
Go to Project Properties->Paths and Symbols->Symbols Tab->GNU C++->__cplusplus Symbol and change to 201103L
It depends on your used type of C++ project and your eclipse version. I have a Makefile project in Eclipse Mars.2 (4.5) with CDT 8.8.1.201602051005) If you have a Makefile project and see the item C/C++ General-->C/C++ Make Projects in your project properties, you also have to go to the tab "Discovery Options" and add -std=c++11 to the Compiler invocation arguments.
kelvinelove
  • 1,619
nils
