Well this is a common problem as i have seen through my google searches but i didn't manage to find any satisfactory solution so far. I got my laptop recently which came with windows 8 pre-installed.I decided to install ubuntu (i had it in my former laptop) but the main problem is that when ubuntu starts the brightness is 0 be default(my laptop has a backlit button too). I can use the Fn buttons to change back to what i want but i wondered if there is a solution after all. The only solutions i found so far set the brightness in a default value which fix the low brightness problem after the start up but i cant control the brightness with the fn buttons afterwards. If anyone has a solution please share. Thanks in advance. ps my laptop is Lenovo G510
            Asked
            Active
            Viewed 722 times
            Well this might be a workaround
Edit you rc.local file which will run on each startup,
sudo gedit /etc/rc.local
to write there something like,
echo 100 > /sys/class/backlight/intel_backlight/brightness
or
echo 100 > /sys/class/backlight/acpi_video0/brightness
depending on what defines your system brightness.
you can find out which brightness value is best for you by looking in the "actual_brightness" file. Then change the 100 for that number.
        Presbitero
- 1,175
- 3
- 11
- 23
