-1
I have been struggling now for an inordinate amount of time trying to get the brightness adjustment working in Ubuntu.
I am running Ubuntu 12.04 on a Lenovo V570 Laptop.
I have tried all of the adjustments I can find to "fix brightness control" in the /etc/default/grub file with the following results (before you ask, yes I did run sudo update-grub and sudo reboot after each change):
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi="
Result: No response to buttons, slider has no affect.
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux acpi_backlight=vendor"
GRUB_CMDLINE_LINUX_DEFAULT="splash quiet acpi_osi='!Windows 2012'"
Result: Limited response to buttons from OS (slider only moves down one tick, then sticks), no dimming, slider has no affect.
GRUB_CMDLINE_LINUX_DEFAULT="splash quiet" Result: OS responds to buttons, but screen does not dim. Slider has no affect.
Am I missing something? What can I do to adjust the brightness?
Update: I did more searching, and I found that in /sys/class/backlight I have both acpi_video0 and intel_backlight. By changing the "brightness" file in each of these folders, I discovered, that editing the /sys/class/backlight/intel_backlight/brightness changed the actual brightness setting on my screen. How do I get Ubuntu to adjust this setting? Any hope of getting my function keys to also adjust it?
Update2:
As requested, here is the output from lspci:
    $ lspci | grep VGA
    00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
Bts
I had the same problem on my ThinkPad x240 running Ubuntu 14.04, and created a script that outputs and lets you step brightness up or down.
This assumes that the manual method of putting a number into /sys/class/backlight/intel_backlight works, so test that first:
sudo tee /sys/class/backlight/intel_backlight/brightness <<< 500
sudo tee /sys/class/backlight/intel_backlight/brightness <<< 300
The script is here:
https://gist.github.com/emning/5d3301a3f3c9420414f7
Save it as 'brightness' somewhere in your path, make it executable and run:
brightness
brightness up
brightness down
You can also bind these commands to shortcut keys, even the standard brightness keys seem to work fine. I used Custom Shortcuts in KDE, but any desktop environment should work.
NOTE: For this to work when using shortcut keys, sudo without password has to be enabled for your user.
emning
  • 111
I was also suffering from same problem,but I found here a solution that worked for me(on Acer Aspire-5738).
If you have acpi_video0 and /sys/class/backlight/intel_backlight/brightness and changing /sys/class/backlight/intel_backlight/brightness is changing your computer brightness , you can force your system to use intel_backlight.
  • Create a file 20-intel.conf in /usr/share/X11/xorg.conf.d/ using following command:
    gksudo gedit /usr/share/X11/xorg.conf.d/20-intel.conf
  • Now paste this
    Section "Device" Identifier "card0" Driver "intel" Option "Backlight" "intel_backlight" BusID "PCI:0:2:0" EndSection
  • Save and logout.
g_p
  • 19,034
  • 59
  • 69
