I want to open a .jar file with java. It is located in /home/myusername. I had to type in the terminal to open it
java -jar filename.jar
I want to have a shortcut that if I click it, it will run the command and launch the program with java automatically..
is there anything I could do?
sourav c.
  • 46,120
You can create a .desktop file on your desktop using your favourite text editor and save the following code in a it.
[Desktop Entry]
Encoding=UTF-8
Name=myjavafile
Type=Application
Exec=java -jar /home/myusername/filename.jar
Icon=/path/to/java.jpg
You need to change Name and jar file name in Exec field. If you want to set an icon for it put a 128x128 .jpg or .png image for java and specify it accordingly on Icon field. Otherwise remove the last line.
Give it execution permission,
chmod +x /home/myusername/Desktop/<filename>.desktop
Now you can click on it to open your jar file using java directly.
sourav c.
  • 46,120
First create an Empty Document and name it yourchoosenname.sh
(.sh means that this file contain commands to run )
Second open this file and add the code you write in Terminal, adjusting the path as appropriate:
java -jar /home/$USER/filename.jar
Third make this file executable:
Right click on the file, then to the Permissions tab.
Fourth run this file by double clicking.
kiri
  • 28,986
nux
  • 39,152
