I tried installing MySQL using
sudo apt-get install mysql-server, and I get an error saying
 mysql-server : Depends: mysql-server-5.1 but it is not going to be installed
When I type sudo apt-get install mysql-server-5.1, it says:
 mysql-server-5.1 : Depends: mysql-client-5.1 (>= 5.1.69-0ubuntu0.11.10.1) but it is not going to be installed
                    Depends: libdbi-perl but it is not going to be installed
E: Unable to correct problems, you have held broken packages."
And when I type mysql, it says,
 ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
I tried sudo apt-get remove --purge mysql-client-5.1 but it says that
mysql-client is not installed so it can't be uninstalled.
What should I do?
Braiam
  • 69,112
And when I type "mysql", it says, "ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)"
You can login to mysql database through
mysql -u root -p
and not mysql
While installation going you mus get prompted for password and you have to give that password here to login.
and to fix dep issue , you might try with
sudo apt-get install -f
Raja G
  • 105,327
  • 107
  • 262
  • 331
