I want to install an ubuntu System to an USB Stick and if I boot this, I don't want it to connect to the internet. Is there a Way to archieve this? I tried
sudo ifconfig eth2 down
But it is up again at the next restaret
Braiam
  • 69,112
jan
  • 151
Method #1 - from NetworkManager's Applet
Try disabling the wireless networking under the Network Applet that's accessible from under the icons in the upper right of your desktop.
                                                    ss #!
NOTE: The networking applet's icon looks like a triangle wedge. The image above is pointing to is as arrow #1. If you click it you should see a menu slide out from where you can disable wireless permanently, arrow #2.
Method #2 - /etc/network/interfaces
From the file /etc/network/interfaces you can specify that NetworkManager shouldn't control the wlan0 interface. To do so simply add this line to the above mentioned file:
iface wlan0 inet manual
Then restart NetworkManager:
$ sudo service network-manager restart
References
slm
  • 3,155
Add sudo ifconfig eth2 down in /etc/rc.local file so at login it will be down.
nux
  • 39,152
-1
Just unplug your cable.
sudo ifdown eth2
Try it...
Wilf
  • 30,732
Beginner
  • 491
