I installed Java 7 and later I got troubles with my system, I can't update anymore. The package system is broken.
Check if you are using third party repositories. If so disable them, since they are a common source of problems. Furthermore run the following command in a Terminal:
  1. sudo dpkg --check ==> no results, does not recognise command
  2. sudo apt-get check
    Reading package lists... Done
    Building dependency tree
    You might want to run 'apt-get -f install' to correct these.
     libc6 : Depends: libgcc1 but it is not installed
             Depends: tzdata but it is not installed
    E: Unmet dependencies. Try using -f.
  3. apt-cache policy debconf
    debconf:
      Installed: (none)
      Candidate: 1.5.42ubuntu1
      Version table:
         1.5.42ubuntu1 0
            500 http://archive.ubuntu.com/ubuntu/ precise/main i386 Packages
  4. apt-get install -f
    libc6: Depends: libc-bin (= 2.15-0ubuntu10.5) but 2.15-0ubuntu10.5 is installed
    sudo apt-get install -f
    Correcting dependencies... Done
    The following extra packages will be installed:
      apt-utils coreutils debconf debconf-i18n dpkg libacl1 libapt-inst1.4
      libapt-pkg4.12 libattr1 libbz2-1.0 libdb5.1 libgcc1 liblocale-gettext-perl
      liblzma5 libselinux1 libstdc++6 libtext-charwidth-perl libtext-iconv-perl
      libtext-wrapi18n-perl perl-base tar tzdata xz-utils zlib1g
    Suggested packages:
      debconf-doc debconf-utils whiptail dialog gnome-utils
      libterm-readline-gnu-perl libgtk2-perl libnet-ldap-perl libqtgui4-perl
      libqtcore4-perl apt bzip2 ncompress xz-lzma
    The following NEW packages will be installed:
    0 upgraded, 24 newly installed, 0 to remove and 0 not upgraded.
    2 not fully installed or removed.
    Need to get 0 B/9303 kB of archives.
    After this operation, 29.7 MB of additional disk space will be used.
    Do you want to continue [Y/n]? y
    perl: warning: Setting locale failed.
    perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LC_TIME = "de_CH.UTF-8",
        LC_MONETARY = "de_CH.UTF-8",
        LC_ADDRESS = "de_CH.UTF-8",
        LC_TELEPHONE = "de_CH.UTF-8",
        LC_NAME = "de_CH.UTF-8",
        LC_MEASUREMENT = "de_CH.UTF-8",
        LC_IDENTIFICATION = "de_CH.UTF-8",
        LC_NUMERIC = "de_CH.UTF-8",
        LC_PAPER = "de_CH.UTF-8",
        LANG = "en_US.UTF-8"
        are supported and installed on your system.
    perl: warning: Falling back to the standard locale ("C").
    locale: Cannot set LC_ALL to default locale: No such file or directory
    E: Cannot get debconf version. Is debconf installed?
    debconf: apt-extracttemplates failed: No such file or directory
    dpkg: regarding .../libgcc1_1%3a4.6.3-1ubuntu5_i386.deb containing libgcc1, pre-dependency problem:
     libgcc1 pre-depends on multiarch-support
      multiarch-support is unpacked, but has never been configured.
    dpkg: error processing /var/cache/apt/archives/libgcc1_1%3a4.6.3-1ubuntu5_i386.deb (--unpack):
     pre-dependency problem - not installing libgcc1
    No apport report written because MaxReports is reached already
    E: Internal Error, No file name for libc6
    W: Could not perform immediate configuration on 'multiarch-support:i386'. Please see man 5 apt.conf under APT::Immediate-Configure for details. (2)
Dan
  • 14,180
If coreutils is not installed, your system is seriously hosed.
Does /bin/date exist and work? If yes, “just” your package database is corrupt. In this case, restore /var/lib/dpkg/status from a backup – e.g. /var/lib/dpkg/status-old or one of the files /var/backups/dpkg.status.* (remember to uncompress the *.gz files).
mirabilos
  • 696
  • 20
