38
There are several programs only available on Windows.
Wine can be a negative experience, so I want to run Windows inside Ubuntu using a virtual machine. It seems that Virtualbox is the standard way, but I don't have any experience with it.
Mateo
  • 8,152
Alejandro
  • 929
10 Answers10
39
I use Virtual Box and it works great.
It's pretty simple to use. After installation, just click the "New" button in the toolbar, and a wizard will walk you through creating the VM.
Afterwards, click "settings", go to "storage" and mount the installation media (either as an .iso or the physical drive itself). Click "ok".
Now you can start the VM and it should allow you to install the OS.
Here is an introduction article on virtualization on workswithu.com. Click on the tags at the bottom of the article for even more info.
jumpnett
  • 6,185
16
I highly recommend at least testing the applications in Wine before virtualizing them. When Wine does work there are some important benefits over virtualization: performance is noticeably better, they're easier to run (links right off the Application menu), and they become integrated with the system (easy access to the files in your home folder, no windows in windows, and if they have a system tray icon it sits in the panel).
If every app you need works in Wine, then you also get the added benefit of not needing a copy of Windows for your virtual machine.
An alternative to testing them in Wine is to look them up in Wine's application database: http://appdb.winehq.org/
Currently, I also recommend using my packages from the Wine PPA rather than the packages that come with Ubuntu (which are also mine). You can get instructions here: https://wiki.winehq.org/Ubuntu -- on 14.04, 16.04, and 17.10 you can install either the wine2.21 or wine3.3 (beta) packages. The 2.21 one will remain stable, while the 3.3 will receive updates as new Wine releases come out -- which means 3.3 will generally work with more apps, but might break on an update as well.
The main advantage of using the PPA packages is that you can find an exe file and just right click->open with Wine without having to manually set it as executable.
Virtualbox is a great choice if Wine doesn't work with a particular application. However, if a program does work well in Wine, Virtualbox may not be preferable, due to the inherent performance loss and the need to boot a full Windows OS. It can also be tricky if you do not have an extra copy of Windows available for installation, because it does involve a fresh install.
I was going to say that DirectX 3D games and apps were out of the question, but research seems to indicate that it now has Direct3D support.
DLH
  • 2,465
VMWare workstation and VMWare player (free) are also options.
codeape
  • 647
In addition to VirtualBox being a perfect solution by technical means, I also find the user experience to be better. If you use a Windows application with Wine, you suddenly have some window on your Ubuntu desktop which may look completely out of place. Technically it runs in Ubuntu, but it often doesn't behave like your remaining Ubuntu applications.
With VirtualBox the separation between both environments is a bit more clear, because you expect the applications inside VirtualBox to behave like Windows applications. This makes the "mental switching" easier and therefore improves your user experience.
Virtualbox is excellent. And strangely Windows XP for me runs quicker in Ubuntu (as a guest) than it ever did in real life! Also oddly the Windows XP recognised my sound card, wireless etc. without the fiddling I had to do when I was using it for real! I have to say that Wine can be useful but the "real thing" works quicker in a virtual XP - I love Ubuntu just that it can't do certain things (Windows is the same) - nothing wrong with that; I tend to think that certain Linux users take a special pride in avoiding Windows at all costs, and stick with some pretty shaky Wine emulations just to say it works (just)! Top tip for installation of Virtualbox seems a minor point - make sure your Windows CD is nice and clean and you've got it in the correct CD Draw (if you have two) - for some reason any tiny flaw on the CD seems more likely to upset the virtual machine than it would in a real installation. Secondly my Windows is a OEM version and it worked, just have your product code to hand - and it works, and activates the product via the internet. What's great if you try to install your OEM windows on a different computer it will often go mad, and you may lose your drivers for onboard sound etc. - with Virtual Box XP no problems - works right out the box.
Jules
  • 31
The best way is to run it as a VM. So yes, virtualbox is a good choice.
txwikinger
  • 29,406
You can give Virtual Box (http://www.virtualbox.org/) a try. It sets up a virtual machine inside your XP opeating system without losing anything. Moreover Virtual Box is free.
User
  • 4,566
QEMU and KVM worked great for me.I installed Windows 10 inside Ubuntu 18.04, and I can not notice much difference from running a normal installation.
A good tutorial is here:
https://dennisnotes.com/note/20180614-ubuntu-18.04-qemu-setup/
To avoid Windows installation errors, I needed to allocate enough disk space (32 Gb for Windows 10). To avoid 10-30x times slowdown I needed to enable virtualization in BIOS before the installation started.
Valentas
  • 1,138
-1
Oracle VM VirtualBox is a program that allows you to create operating systems on virtual machines, i.e. to use Windows programs on Linux. If a program doesn't work under WINE, for example, it will probably work in its native environment, Windows. Using VirtualBox would be a better and easier alternative than installing a separate partition for Windows on a Linux machine.
