i want to connect two soft phone using asterisk after configuration the sip.conf and iax.conf and extension.conf can't enter any order from cli example of the error:
Connected to Asterisk 11.6-cert1 currently running on fedo-VirtualBox
(pid = 1066)
fedo-VirtualBox*CLI> sip show peers
No such command 'sip show peers' (type 'core show help sip show' for
other possible commands)
Volker Siegel
  • 13,295
fedo
  • 51
module show like sip
is returning something?
if not do this
module load chan_sip.so
and try again
AlexGreg
  • 1,675
  • 13
  • 18
I tried the above answer and it still failed. Reason was: chan_sip.so was not there in modules folder.
So, I uninstalled the asterisk
make uninstall
Then I started installing the asterisk-13 again
./configure
make menuconfig
In menu select, go to channel drivers option and check the checkbox chan_sip [Probably unchecked]. Then, do the below command
make & make install & make config
In my case i have installed asterisk through yum so recompiling will not work for me so i search yum repo for chan_sip.so
[root@MTL-189551 asterisk]# yum whatprovides */chan_sip.so
Note it is very necessary to install the correct version of the module i have installed Asterisk 13.17.2 so it is very necessary to install same module
In yum search result i found this version
asterisk-sip-13.17.2-vici.el7.centos.x86_64 : Legacy SIP channel driver for
Asterisk
Repo        : goautodial-updates
Matched from:
Filename    : /usr/lib64/asterisk/modules/chan_sip.so
[root@MTL-189551 asterisk]# yum install asterisk-sip-13.17.2
Before restart asterisk add below line
[root@MTL-189551 ~]# vim /etc/asterisk/modules.conf
Find the below line in file and uncomment or add
require = chan_sip.so
After this restart your asterisk and connect to asterisk console and check whether module is loaded or not
    MTL-189551*CLI> module show like chan_sip.so
Module                         Description                              Use Count  Status      Support Level
chan_sip.so                    Session Initiation Protocol (SIP)        0          Running              core
1 modules loaded
MTL-189551*CLI>
