Hi I am new to Ubuntu Linux, I have installed on my dell latitude d600 every thing's smooth and fast, I have bean trying to install Google chrome, which I would like to use on Ubuntu, but unfortunately, it shell will not let me install it on my laptop.
Try the following.
Use this code for 32-bit system:
sudo apt-get install libxss1
wget https://dl.google.com/linux/direct/google-chrome-stable_current_i386.deb
sudo dpkg -i google-chrome*.deb
For 64-bit system use:
wget https://dl.google.com/linux/direct/google-chrome-stable_current_amd64.deb
This installs a needed library for Google Chrome, then downloads the latest version of Chrome to the current working directory and installs it.
Run google-chrometo start the browser.
You can also download it here Download Google Chrome.
- 221
- 1
- 7
Non terminal Method
If you are not a much of a terminal user you can go ahead to this link and download directly.
Using terminal
Step 1: Getting .deb installer
For Google Chrome 32-bit version
For Google Chrome 64-bit version
Step 2: Installing Google Chrome
Use this command to install Google Chrome or you can also do it by double clicking the downloaded file.
Use the code below if you prefer doing it using terminal command
google-chrome* refers to the full name of the file you installed
sudo apt-get -f install
Now you have successfully installed Google Chrome. Launch it by searching Chrome in Unity Dash.
Enjoy!
You can also refer to my blogpost here
- 837
