where in virtualbox do you install Windows XP guest with Ubuntu 12.04 LTS as host.
Asked
Active
Viewed 1,067 times
Create a new virtual machine, set the type to Windows XP, add a virtual harddisk (type: IDE is recommended), attach a Windows XP install ISO to the guest CD drive, start the machine. Installation will run normally inside the guest. After the OS is installed, it is recommended to install the Virtualbox Guest Additions inside the guest VM.
Alternately, if you're looking to test old IE versions, you could download pre-made virtual machines from http://modern.ie/
